Company Holidays: December 22, 2025 – January 5, 2026
CODESYS SoftMotion Axes (4)
With this license, up to 4 real axes, and additionally 4 virtual axes, can be controlled.
2305000009
€160.00
Functional principle
Typical applications
All supported by CODESYS:
WIBU Codemeter Support
