CODESYS Control Standard S
The application-based CODESYS Control Standard S license is specially designed for applications with a complex fieldbus instance. It contains 512 I/O channels and can be used on all Control SL products without restrictions.
2302000050
From €119.00
License Control Standard S
Metric
Basic L
Standard S
Standard M
Fieldbus instances
2
4
8
Complex fieldbus instances
1
1
1
thereof host instances
0
1
1
1
1
1
Number of I/O channels
256
512
1024
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic C code
No
Yes
Yes
No
No
No
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
