CODESYS Automation Server 2315000005 Subscription€0.00With the CODESYS Automation Server, you can manage, monitor, and control your automation landscape remotely. Update, debug, and maintain your CODESYS projects and applications at any location—all via secure, centralized access to all your connected devices and associated CODESYS projects.
Learn More
Log in with your CODESYS Store account to set up your access to the CODESYS Automation Server. -
New!
CODESYS Automation Server On-Prem 25 2315000020 Subscription€749.00With the CODESYS Automation Server On-Prem 25 license, you connect up to 25 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
Learn More -
New!
CODESYS Automation Server On-Prem 100 2315000021 Subscription€2,996.00With the CODESYS Automation Server On-Prem 100 license, you connect up to 100 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
Learn More -
New!
CODESYS Automation Server On-Prem 250 2315000022 Subscription€7,490.00With the CODESYS Automation Server On-Prem 250 license, you connect up to 250 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
Learn More -
New!
CODESYS Automation Server On-Prem 500 2315000023 Subscription€14,980.00With the CODESYS Automation Server On-Prem 500 license, you connect up to 500 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
Learn More -
Traffic 2315000009€0.10The incoming and outgoing data traffic on the CODESYS Automation Server is billed with the Traffic.
Only available as a service of the CODESYS Automation Server product.
Learn More -
Storage 2315000008€0.40All storage used on the CODESYS Automation Server is billed with the Storage.
Learn More -
PLC Management 2315000006€3.49 As low as €2.62PLC Management is a service within the CODESYS Automation Server that is used for billing the management of controllers.
Learn More -
Free!
Data Analyzer EVAL Project 2315000010€0.00Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
10 data points
10 records per hour
Learn More -
Data Analyzer XXS Project 2315000011€0.07Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
25 data points
100 records per hour
Learn More -
Data Analyzer XS Project 2315000012€0.14Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
50 data points
250 records per hour
Learn More -
Data Analyzer M Project 2315000014€0.28Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
500 data points
1.000 records per hour
Learn More -
Data Analyzer L Project 2315000015€0.36Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
1.000 data points
2.500 records per hour
Learn More -
Data Analyzer XL Project 2315000016€0.50Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
2.500 data points
5.000 records per hour
Learn More -
Data Analyzer XXL Project 2315000017€0.83Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
5.000 data points
10.000 records per hour
Learn More -
Data Analyzer XXXL Project 2315000018€1.39Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
10.000 data points
20.000 records per hour
Learn More -
Data Analyzer MAXIMUM Project 2315000019€2.22Data analyzer projects are probably the easiest way to remotely monitor, operate and analyze machine and plant controls - thanks to cloud technology from anywhere in the world.
Includes:
30.000 data points
50.000 records per hour
Learn More -
Free!
CODESYS Edge Gateway for Linux 000120€0.00The CODESYS Edge Gateway is an extended CODESYS Gateway connecting the CODESYS Automation Server to CODESYS PLCs in a local network.
Learn More -
Free!
CODESYS Service Tool 000117€0.00The CODESYS Service Tool is a stand-alone program for the configuration of CODESYS Edge Gateways.
Learn More -
Free!
CODESYS Automation Server Connector 000107€0.00The CODESYS Automation Server Connector is an Add-on for the CODESYS Development System to synchronize projects on the CODESYS Automation Server and to configure CODESYS Edge Gateways.
Learn More -
Free!
CODESYS Edge Gateway for Windows 000110€0.00The CODESYS Edge Gateway is an extended CODESYS Gateway connecting the CODESYS Automation Server to CODESYS PLCs in a local network.
Learn More
