Data Analyzer MAXIMUM Project
Includes:
  • 30.000 data points
  • 50.000 records per hour
2315000019
€2.22
Display
Change
  • Tag display (via the “Activate input” option)
  • Wheel
  • Slider
  • Button
  • Toggle (only for logical values)
Record
  • Periodical: Recording at different intervals (10 seconds, 1 minute, 5 minutes, …)
  • Delta: The value is recorded as soon as its value changes by a delta to be defined. This allows for accurate recording of rapid changes.
  • Change: The value is recorded as soon as it changes. Ideal for setpoints or states.
Projec size of the Data Analyzers
Number of data points
Records per hour
EVAL Project
10
10
XXS Project
25
100
XS Project
50
250
S Project
200
500
M Project
500
1.000
L Project
1.000
2.500
XL Project
2.500
5.000
XXL Project
5.000
10.000
XXXL Project
10.000
20.000
MAXIMUM Project
30.000
50.000
More Information
Is free No
Manufacturer INT-EN-nosupport
Disable Add To Cart With price display
Third Party Licence: Type Disabled
