CODESYS Edge Gateway for Linux
The CODESYS Edge Gateway is an extended CODESYS Gateway connecting the CODESYS Automation Server to CODESYS PLCs in a local network.
4.23.0.0
000120
The CODESYS Edge Gateway allows the CODESYS Automation Server and all clients that establish a connection via the Automation Server (CODESYS, Webvisu/Browser) full access to all services provided by the runtime system via communication interfaces. It can be operated on a controller or on a stand-alone device in the local network.
CODESYS Development System Version 3.5.16.0 or higher (Only required for the configuration of the gateway)
CODESYS Control V3.5.10.0 or higher
  • Debian- or Ubuntu-based Linux (32/64 Bit)
  • CPU: x86, x64, ARMv7, ARMv8
  • Access to a CODESYS Automation Server
  • Installation of CODESYS Automation Server Connector plug-in
  • Reliable system clock on the target device running the CODESYS Edge Gateway.
  • Dynamic libraries needed by the CODESYS Edge binary: - libc >= 2.34 - libstdc++6 >= 6.3.0
Currently no support for CODESYS V2 PLCs.
22.10.2026
- 17.08.2026
- 18.06.2026
- 01.04.2026
- 12.02.2026
- 16.10.2025
- 26.08.2025
- 03.06.2025
- 07.04.2025
- 03.12.2024
- 29.08.2024
- 23.02.2024
- 31.10.2023
- 27.07.2023
- 05.04.2023
- 25.01.2023
- 27.10.2022
Includes the following Security fixes: 2021-12
30.06.2022
01.03.2022
01.09.2021
Important Note
  • ARM 64Bit version available
  • Added error message for installation on not supported platforms
COMPATIBILITY INFORMATION * Cfg file setting ListenPort for component ‘CmpBlkDrvTcp’ is not required anymore and was deactivated by default.
16.06.2021
- 04.03.2021
New independet release cycle The Linux-based Edge Gateway is now independent of the CODESYS Development System release cycle. Users profit from faster updates and bug fixes. Version number changed without compatibility break (gateway based on CODESYS Runtime Toolkit V3.5 SP16 Patch2).
17.12.2020
We strongly recommend to replace all existing CODESYS Edge Gateway for Linux - BETA VERSIONs by CODESYS Edge Gateway for Linux V3.5.15.10 or higher.
24.09.2019
