Data Analyzer XXXL Project
Includes:
10.000 data points
20.000 records per hour
Display
Change
Tag display (via the “Activate input” option)
Wheel
Slider
Button
Toggle (only for logical values)
Record
Periodical: Recording at different intervals (10 seconds, 1 minute, 5 minutes, …)
Delta: The value is recorded as soon as its value changes by a delta to be defined. This allows for accurate recording of rapid changes.
Change: The value is recorded as soon as it changes. Ideal for setpoints or states.
Projec size of the Data Analyzers | Number of data points | Records per hour |
EVAL Project | 10 | 10 |
XXS Project | 25 | 100 |
XS Project | 50 | 250 |
S Project | 200 | 500 |
M Project | 500 | 1.000 |
L Project | 1.000 | 2.500 |
XL Project | 2.500 | 5.000 |
| Requirements |
