CODESYS Automation Server
With the CODESYS Automation Server, you can manage, monitor, and control your automation landscape remotely. Update, debug, and maintain your CODESYS projects and applications at any location—all via secure, centralized access to all your connected devices and associated CODESYS projects.
Log in with your CODESYS Store account to set up your access to the CODESYS Automation Server.
2315000005
Details
Basics
The CODESYS Automation Server is a cloud-based Industry 4.0 platform designed for the centralized management, monitoring, and maintenance of automation landscapes. It enables efficient control of the entire lifecycle of machines and plants — from commissioning and maintenance to data analysis. A key feature is the extensive remote access to the connected control systems.
Access
You can create your personal CODESYS Automation Server via the CODESYS Store. This will also give you an administrator account for your CODESYS Automation Server. You can use this to create additional users, manage permissions, and make full use of the CODESYS Automation Server. You can also cancel your CODESYS Automation Server via the CODESYS Store on a monthly basis. Upon cancellation, all data stored on your CODESYS Automation Server will be permanently deleted.
Infrastructure
The CODESYS Edge Gateway enables communication between the CODESYS Automation Server and connected PLCs. It also serves as a remote CODESYS Gateway, allowing the CODESYS Development System to connect to remote PLCs. It can be installed on dedicated hardware or directly on a PLC – on both Linux and Windows. The CODESYS Edge Gateway encapsulates the PLC world from the outside and ensures secure communication via a TLS connection to the CODESYS Automation Server. The CODESYS Automation Server Connector is an add-on for the CODESYS  Development System that enables projects to be synchronized with the CODESYS Automation Server. Simple merge mechanisms allow multiple application engineers to work on a project together and ensure audit-proof storage of the current progress.
CODESYS Development System Version 3.5.15.0 or higher
CODESYS Control V3.5.8.0 or higher
Additional requirements for the controller:
  • File system required
  • Unique controller name within a controller network; alternatively addressing via IP address/host name
  • Unique serial number; if no serial number is available, a writable persistent configuration file is required
CODESYS Edge Gateway V3.5.16.0 or higher
CODESYS Gateway V3.5.10.0 or higher
Cloud Service Provider
  • Amazon Web Services
Browser 1
  • Firefox
  • Safari
  • Chrome
  • Edge
  • CODESYS Edge Gateway V3.5.16.0
  • CODESYS Automation Server Connector V1.23.0.0
1 These are the oldest versions we work and test with. It is possible that older versions of these browsers or alternative browsers that are not in this list are supported.
More Information
Is free No
Browser 1
  • Firefox
  • Safari
  • Chrome
  • Edge
Manufacturer INT-EN-support
Disable Add To Cart No
Third Party Licence: Type Disabled
