CODESYS Control Performance L
The application-based CODESYS Control Performance L license is specially designed for applications with the highest performance requirements. The function of pinning task groups to isolated cores enables a significant reduction in task jitter. The license also includes eight complex fieldbus instances and 16384 I/O channels. It can be used on all Control SL products without restrictions.
2302000054
From €599.00
License Control Performance L
Metric
Performance M
Performance L
Performance XL
Fieldbus instances
12
16
16
Complex fieldbus instances
4
8
16
thereof host instances
4
8
8
4
8
16
Number of I/O channels
8192
16384
65535
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic C code
Yes
Yes
Yes
Yes
Yes
Yes
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
