CODESYS Control Standard M
The application-based CODESYS Control Standard M license is specially designed for applications with a complex fieldbus instance. It contains 1024 I/O channels and can be used on all Control SL products without restrictions.
2302000051
From €139.00
License Control Standard M
Metric
Standard S
Standard M
Standard L
Fieldbus instances
4
8
10
Complex fieldbus instances
1
1
2
thereof host instances
1
1
2
1
1
2
Number of I/O channels
512
1024
4096
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic C code
Yes
Yes
Yes
No
No
Yes
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
