CODESYS SoftMotion Axis Groups/CNC Interpolators (1)
With this product 1 axis group or 1 CNC interpolator can be controlled.
2305000015
€160.00
Functional principle
  • Integrated motion planning:
Typical applications
All supported by CODESYS:
WIBU Codemeter Support
