CODESYS Control Performance M
The application-based CODESYS Control Performance M license is specially designed for applications with the highest performance requirements. The function of pinning task groups to isolated cores enables a significant reduction in task jitter. The license also includes four complex fieldbus instances and 8192 I/O channels. It can be used on all Control SL products without restrictions.
2302000053
From €349.00
License Control Performance M
Metric
Standard L
Performance M
Performance L
Fieldbus instances
10
12
16
Complex fieldbus instances
2
4
8
thereof host instances
2
4
8
2
4
8
Number of I/O channels
4096
8192
16384
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic C code
Yes
Yes
Yes
Yes
Yes
Yes
CODESYS Communication
CODESYS Visualization
CODESYS SoftMotion Axes
Description of properties
Trial Operation
License check
Upgrade licenses
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
