Upgrade to CODESYS Control Standard M
Upgrade of an already purchased application-based license (Base License) to the application-based license Standard M. The costs of the already purchased license (Base License) are fully credited.
This product can be used to upgrade the application-based license installed on the system to the Standard M application-based license.
A description of the application-based license Standard M can be found here:
https://store.codesys.com/en/codesys-control-standard-m-bundle.html
Programming System | CODESYS Development System Version 3.5.19.10 or higher |
Runtime System | Control SL V4.9.0.0 or higher (build on runtime system SDK V3.5.19.10) |
Supported Platforms / Devices |
Runtime System Updates | This product does not affect the update authorization of the previously installed licence. It is neither shortened nor extended. |
Additional Requirements | - |
Restrictions |
Licensing | Single device license: The license can be used on the target device/PLC on which the CODESYS runtime system is installed. Licenses are activated on a software-based license container (soft container), which is permanently connected to the controller. Alternatively, the license can be stored on a CODESYS Key (USB dongle). By replugging the CODESYS Key, the license can be used on any other controller. Note: In demo mode, the software runs for two hours without a license. After that, a manual restart is required. |
Required Accessories | Optional CODESYS Key Version 3-xxxxxx (version 2-xxxxxx is not supported) |
