This product will be replaced by the new platform-independent, application-based software licenses on 06/30/2024. For more information on application-based licenses, click here. Please note that the usage of the application-based licenses requires the CODESYS Development System V3.5.19.50 or higher.
CODESYS Control RTE MC SL
A multicore extension for CODESYS Control RTE SL - an IEC 61131-3 compliant real-time SoftPLC for PC-based industrial controllers under Windows.
2302000043
€110.00
Plus 19% VAT
Single Device License
The product CODESYS Control RTE SL is a real-time software PLC for PC-based industrial controllers under Windows. The runtime system has its own real time kernel, which enables deterministic behavior with jitter values in the µs range without additional hardware components or operating system extensions.
The mutlicore license CODESYS Control RTE MC SL extends the CODESYS Control RTE SL by the ability to distribute the IEC application over several CPU cores. The application engineer decides whether the distribution of tasks should be handed over to the operating system or whether tasks such as motion, communication or visualization should be processed on individual cores. With the multicore extension the optimal distribution can be set for each application and monitored via integrated core tracing.
Benefit
  • Better real-time behavior of independent tasks
  • Better performance of the overall system
  • More options for load distribution in the operating system
  • Preservation of data consistency
  • Longer CPU life
Functions
  • Runtime system extension for multicore operation of CODESYS Control RTE SL
  • Extension of the task configuration in the CODESYS Developement Systems for binding individual IEC tasks (tasks or task groups) to different CPU cores
  • Tracing of the load distribution of the multicore application within CODESYS
Fieldbus support
Fieldbuses are licensed within the CODESYS Control RTE SL product.
CODESYS Development System V3.5.17.10 or higher
CODESYS Control RTE SL V3.5.17.10 or higher
OS: Windows 8 / 10 / Embedded CPU: x86 (single core), x64 (multi core)
Installation of CODESYS Control RTE SL
