CODESYS Control RTE SL (for Beckhoff CX)
3.5.19.20
2302000001
From €554.00
The product CODESYS Control RTE SL is a real-time software PLC for PC-based industrial controllers under Windows. The runtime system has its own real time kernel: deterministic behavior with jitter values in the µs region without additional hardware components or operating system extensions.
Interfaces
  • CODESYS OPC UA Server
The following CAN-PCI cards are supported:
  • Peak PCI: PCIe, MiniPCIe
  • Ixxat: SJA1000 (PCI card)
  • Automata: all PCI cards (1- and 2-channel)
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS J1939
  • CODESYS PROFIBUS Master
  • CODESYS Sercos III Master
Product options
The product can be extended by the following chargeable options:
  • CODESYS SoftMotion SL
  • CODESYS WebVisu SL
  • CODESYS TargetVisu SL
CODESYS Development System V3.5.17.20 or higher
OS: Windows 8 / 10 / Embedded CPU: x86 (single core), x64 (multi core)
The following CAN-PCI cards are supported: - Peak PCI: PCIe, MiniPCIe (SJA1000-based) - Ixxat: SJA1000 (PCI card) - Automata: all PCI cards (1 and 2 channel)
The following Ethernet chipsets are supported: - Realtek - Intel
Sercos III Master: only 32bit supported
Version .zip with packed Setup.exe (32 and 64 bit) .zip with unpacked Setup (32 and 64 bit) Release Notes Release Date
3.5.19.20
03.08.2023
3.5.19.10 - 01.06.2023
3.5.19.0
08.03.2023
3.5.18.50
04.05.2023
3.5.18.40
13.12.2022
3.5.18.30
06.10.2022
3.5.18.20
03.06.2022
3.5.18.0
Includes the following Security fixes: 2021-09, 2021-11, 2022-02, 2022-03, 2022-04, 2022-05, 2022-06, 2022-07
06.04.2022
3.5.17.50 - 28.10.2022
3.5.17.40 - 10.06.2022
3.5.17.20
02.11.2021
3.5.17.10
23.07.2021
3.5.17.0
28.04.2021
3.5.16.50
26.05.2021
3.5.16.40
28.01.2021
3.5.16.30
19.11.2020
3.5.16.20
3.5.16.10
3.5.16.0
07.04.2020
3.5.15.50
22.06.2020
3.5.15.40
3.5.15.30
3.5.15.20
3.5.15.10
19.09.2019
3.5.15.0
3.5.14.40 - 23.08.2019
3.5.14.30
3.5.14.20 - 18.04.2019
3.5.14.10
20.02.2019
3.5.14.0 17.12.2018
3.5.13.40
16.05.2019
3.5.13.30
18.01.2019
3.5.13.20
23.10.2018
3.5.13.10
23.08.2018
3.5.13.0
(Link to Advisory 2018-06)
Compatibility Information:
10.07.2018
3.5.12.70
13.11.2018
3.5.12.60
18.09.2018
3.5.12.50
17.07.2018
3.5.12.40
24.05.2018
3.5.12.30 27.04.2018
3.5.12.20
15.03.2018
3.5.12.10
For more details see:
26.02.2018
3.5.12.0 - 20.12.2017
3.5.11.60
20.04.2018
3.5.11.50
16.02.2018
3.5.11.40 - 17.11.2017
3.5.11.30 - 17.10.2017
3.5.11.20 - 21.09.2017
3.5.11.10 - 22.08.2017
3.5.11.0 - 14.07.2017
3.5.10.60 - 23.08.2017
3.5.10.50 - 17.07.2017
3.5.10.40 - 22.05.2017
3.5.10.20 - 16.03.2017
3.5.10.10 - 14.02.2017
3.5.10.0 - 14.12.2016
3.5.9.70 - 22.02.2017
3.5.9.60 - 20.01.2017
3.5.9.50 - 17.11.2016
3.5.9.40 - 02.11.2016
3.5.8.60 - 23.09.2016
