For more information on application-based licenses, click here.
SoftMotion Axis Groups/CNC Interpolators (2)
With this product 2 axis groups or CNC interpolators can be controlled.
2305000016
€300.00
Base License
This license also acts as an upgrade license from an already purchased CODESYS SoftMotion license (Base License) to a bigger license. The costs of the already purchased license (Base License) will be fully credited.
By default, the runtime system license does not include a SoftMotion license. The SoftMotion license can be added optionally.
Functional principle
  • Integrated motion planning:
Typical applications
All supported by CODESYS:
  • Devices with integrated fieldbus (EtherCAT, CAN/CANopen, or Sercos)
WIBU Codemeter Support
