OPC UA Client Example
The example ‘OPCUAClient_Example’ demonstrates how to use the CODESYS OPC UA Client programmatically. It contains visualizations to access the applied functions via a user interface. The example ‘OPCUA_Datasource_Example’ demonstrates how a CODESYS OPC UA connection can be set up via data source manager.
1.1.0.0
000119
‘OPC UA Client Example’ demonstrates how to use the IEC 61131-3 interface of the CODESYS OPC UA Client. It contains function blocks to connect to and exchange data with other OPC UA Servers. Also it contains two visualizations to operate the cited function blocks via a user interface and check server certificates.
‘OPC UA Datasource Example’ uses for communication between server and client the data source manager. A direct read of values in device set can be done in client.
Development system
Runtime
CODESYS Control V3.5.17.0 or higher
Additional requirements
Runtime system component CmpOPCUAClient
  • The connection to OPC UA Servers is possible via an IP address only, not via a host name.
  • To establish secure server-client communication, a client certificate has to be generated on the controller by means of the CODESYS Security Agent (https://store.codesys.com/codesys-security-agent.html) before the connection is established.
Required accessories
Added new example OPCUA_Datasource_Example
29.04.2022
- 02.10.2020
