This product is currently in the service phase and will be discontinued in the future. We recommend using it only for existing projects. For new developments, CODESYS Virtual Safe Control is available as an alternative. Further information: Discontinuations
CODESYS Safety for EtherCAT Safety Module SL
CODESYS extension for EtherCAT based safety solutions with TwinSAFE logic modules EL6900, EL6910 and EK1960 from Beckhoff under a CODESYS controller with CODESYS EtherCAT Master stack.
4.5.0.0
2306000000
€165.00
The TÜV certified product allows to extend any CODESYS project with an EtherCAT controller with CODESYS EtherCAT Master stack for the development of safety functions with TÜV certified safety logic modules by Beckhoff and digital FSoE I/O modules and analog TSC input modules in the EtherCAT network. The extension with safety-specific editors and configurators is integrated seamlessly into the CODESYS Development System and the CODESYS EtherCAT configurator. It enables cost effective and scalable realization of simple safety applications with zero sytem integration or adaptation effort and low acceptance expenditure. The product is aimed at users and at device manufacturers who do not intend to develop their own safety controller and require only limited safety functionality.
  • Safety level up to PL-e according to DIN EN ISO 13849 and up to SIL3 according to IEC 62061/61508, depending on input and output devices and programmed logic.
  • Simplified acceptance by Limited Variability Programming (LVL) according to ISO 13849 and IEC 62061.
  • Logic modules: EL6900 or EL6910 as EtherCAT camp (TwinSAFE-Logic), or EK1960 as EtherCAT coupler (TwinSAFE-Compact Controller) by Beckhoff, or EL1918, EL2912, EL2911
  • Digital SIL3 I/O-modules: FSoE modules (Failsafe over EtherCAT) by any manufacturer installed from EtherCAT description files.
  • Analog SIL2 input modules: 10 TSC modules (TwinSAFE SingleChannel) by Beckhoff: EL3124-0090, EL3174-0090 (differential), EL3214-0090 (for resistance sensors), EL3314-0090 (for thermal element), EL3356-0090 (for weight cell/resistance bridge); and encoders/givers EL5001-0090 (SSI), EL5021-0090 (Sin/Cos), EL5032-0090 (EnDat2.2), EL5101-0090 (incremental differential RS422), EL5151-0090 (incremental)
Operation functions and fieldbus configuration on the standarc controller can be changed without impact on the safety functions of the safety logic module.
  • Standard signals can be exchanged with the EtherCAT controller: standard input signals for comparison with TSC values, signals from/to the standard application.
  • Multiple safety logic modules within an EtherCAT network are possible.
  • Groups: Monitoring of multiple safety areas by one safety logic module supported by dividing the safety application into “groups” of I/O modules with related logic in an IEC 61131-3 POU in FBD language. Each group is started, stopped, diagnosed and error acknowledged separately by the standard application.
  • Optional devices: If a safety area is not present in the machine, EL6910 and EK1960 allow to deactivate the corresponding group by online command without chaning the application (permanently, temporarily, passivated).
Lifecycle
This product is entering the Service Phase on 16.10.2026, and its discontinuation has already been scheduled. We therefore recommend that you only use it for existing projects. Other solutions are available for new developments.
CODESYS V3.5 SP16 Patch 3 (64 bit, 32 bit),
or a version listed in column “Compatibility” under “All versions”
Do not use together with GIT or SVN.
Programming Platform
Windows 10 (64 bit)
CODESYS Control V3.5 SP4 (or higher)
License for CODESYS EtherCAT Master on the controller
Supported Devices
  • 3 logic modules: EL6900, EL6910, EK1960 (Beckhoff TwinSAFE-Logic, TwinSAFE-Compact Controller)
  • logic modules as FSoE I/O-modules: EK1960, EL1918, EL2912, EL2911
  • installed FSoE I/O-modules (no SRA-parameters or preconfigured)
  • 10 analog TSC input modules: EL3124-0090, EL3174-0090, EL3214-0090, EL3314-0090, EL3356-0090, EL5001-0090, EL5021-0090, EL5032-0090, EL5101-0090, EL5151-0090 (Beckhoff TwinSAFE SingleChannel)
No configuration of SRA-parameters; no installation of further TSC modules from description files; no PROFIsafe support
Note: In demo mode, the software runs for two hours without a license. SAFE STATE WILL BE ENTERED AFTER EXPIRY OF TWO HOURS!
Version Compatibility Release Notes Release Date
Compatibility_Information_ESM_4.5.0.0
12.11.2026
Compatibility_Information_ESM_4.4.0.0
29.08.2024
Compatibility_Information_ESM_4.3.2.0
27.03.2023
Compatibility_Information_ESM_4.3.1.0
Support of new logical Beckhoff modules EL1918, EL2912, EL2911
27.04.2022
Compatibility_Information_ESM_4.3.0.0
09.12.2021
Compatibility_Information_ESM_4.2.0.0
15.12.2020
Compatibility_Information_ESM_4.1.0.0
Initially valid CODESYS version: CODESYS V3.5 SP15 Patch 4. Further valid CODESYS version will be listed in column “Compatibility”.
No known current safety-related issues to consider for influence on programmed safety functions. In case you are using older versions, please consider these known severe or safety-related issues: Errata_SafetyRelated.
  • Improved and extended checks of ESM device’s project limits
    (number of function blocks, groups, image size, …)
  • Support of old projects: old ESM devices do not need to be updated;
    convenient update via UpdateEnvironment dialog (up-to-date device descriptions are precondition for some device-related improvements).
22.05.2020
3.5.14.30
  • Support for 10 TwinSAFE SingleChannel analog input modules
  • Support for FSoE modules with pre-configured SRA-parameters
  • Support for group deactivation (project configuration)
27.09.2019
 3.5.11.50
CODESYS Safety for EtherCAT Safety Module 4.0.3.0 is a major product extension.
  1. The product now supports 3 EtherCAT safety modules from Beckhoff: TwinSAFE-Logic EL6910 and Compact Controller EK1960 are supported additionally to TwinSAFE-Logic EL6900. This includes support for - the changed EL6910/EK1960 target format (compile, decompile and compare)
  • analog values (data types, function blocks, monitoring, data exchange with the main PLC)
  • connecting Beckhoff’s patented analog TwinSafe SC modules (e.g. EL3314-0090); note the restriction below
  1. Compatibility with CODESYS 64 bit: CODESYS ESM can be installed on CODESYS 64bit as well.
Known Restrictions:
- TwinSafe SC modules cannot be installed from EtherCAT description files (xml). A CODESYSY package with a selection of TwinSafeSC device descriptions is available separately.
14.03.2018
3.5.9.60 See Features and Changes for more information.
07.03.2017
3.5.8.10 See Features and Changes for more information.
10.03.2016
3.5.6.30
3.5.6.70
03.12.2015
29.04.2015
26.02.2015
