Safety without compromise: With CODESYS Virtual Safe Control SL, you get a certified SIL3 controller without any special hardware requirements. Install it on your commercial-off-the-shelf hardware and experience maximum safety - only with CODESYS.
Its safety functionality is based on the certified component CODESYS Safe Control Core - safety manual and certificate of the core apply to this product.
Immerse yourself in the future of industrial control technology with the revolutionary CODESYS Virtual Safe Control SL. This groundbreaking software solution redefines safety and sets new standards in performance, flexibility and efficiency. Developed without hardware requirements according to IEC 61508, it offers you unrivalled freedom in your choice of industrial hardware.
The benefits are unrivalled: By eliminating the need for IEC 61508 hardware certification, you significantly reduce your time-to-market. With CODESYS Virtual Safe Control SL, you can use the software directly without having to carry out time-consuming hardware tests. The use of the latest CPU generations guarantees impressive performance that takes your production processes to a new level. level.
Safety first: With a hardware fault tolerance (HFT) of 1 and a probability of failure (PFH) of maximal 1 * 10 -10, CODESYS Virtual Safe Control SL offers unrivalled safety. The software can be easily updated as all standard software update paths are supported, in particular through the use of container technology. In addition, the isolated execution as a Linux container guarantees the highest security standards and protects your systems from cyber threats. Discover today how CODESYS Virtual Safe Control SL can optimise your production processes and lead your company safely into the future.
CODESYS Virtual Safe Control SL is delivered exclusively as a container image. If you want to run the safe control system natively on the Linux operating system, the CODESYS Safe Control SL product is available for this purpose.
The license cost is based on the number of safe connections defined in the IEC application. The number of safe connections is therefore equal to the number of assigned safe addresses (e.g. number of assigned F-addresses for Profisafe). Only safe connections are counted, exchange variables for data exchange with standard PLC are not counted.
Programming system
Runtime system
Supported platforms
Debian Linux, RedHat Enterprise Linux, Yocto Linux (x86-64, ARM64)
Additional requirements
Support of a container engine required (Docker/Podman)
Virtual Control SL to run PROFINET and/or EtherCAT communication
Second independend time source
Optimisation of Linux version for real-time (RT_preempt patch)
Limitations
When using the CODESYS Virtual Safe Control SL, the information in the associated Release Information Document must be observed!
When using the CODESYS Virtual Safe Control SL, the workarounds in the CODESYS Safe Control Core Errata List must be taken into account.
Application-based network license: The runtime system is licensed via application-based licenses that are provided by a license server. The number of licenses determines how many controllers can be supplied at the same time.
The license server can be operated in the local network or locally on the same device on which the controllers to be licensed are running.
Note: Without a license, each controller runs in demo mode for two hours.
