This product will be replaced by the new platform-independent, application-based software licenses on 12/31/2023. For more information on application-based licenses, click here. Please note that the usage of the application-based licenses requires the CODESYS Development System V3.5.19.10 or higher and a Control SL Runtime V4.9.0.0 or higher.
CODESYS CANopen Device SL
Configurator, protocol stack and diagnostics for CANopen Device, fully integrated in the IEC 61131-3 development system.
2303000234
€70.00
The CANopen support in CODESYS is based on the standard implementation of the CAN-Interface (CAN Minidriver interface). If your target device programmable with CODESYS is equipped accordingly you can immediately use CODESYS CANopen.
CODESYS CANopen Device offers
  • A CANopen Device configurator integrated in the Development System CODESYS
    ⇒ No additional tools required for the configuration of the bus system or the I/O data.
  • A CANopen communication stack in form of a CODESYS CiA 301 library
    ⇒ The protocol stack is portable across different platforms and does not have to be fully implemented on the device.
    ⇒ The IEC 61131-3 Development System compiles the stack and the application code into native machine code and loads it onto the controller.
  • An application interface for diagnosis and object dictionary access
    ⇒ Extensive functionality without needing any additional software tools
CODESYS Development System V3.5.4.0 or higher
CODESYS Control V3.5.4.0 or higher
Target device needs CAN Minidriver implementation.
