Visualization Elements
This example shows the use of some visualization elements and events, e.g. working with external pictures or rotating objects with mouse events.
000023
To include an external image, an Image Pool object must be added. The included images must use the ID from the Image Pool for the Static ID property.
Some mouse events are directly supported from the visualization (OnMouseClick, OnMouseDown, OnMouseLeave, OnMouseEnter, OnMouseUp and OnMouseMove). Additional ones (double click, dragging) were implemented in the "MouseEvents" program. This example changes the color of an object when an event occurs.
Another function is the rotation. This function can distinguish between interior and normal rotation. In both cases the element rotates around the center point of the element. With the interior rotation, the element additionally rotates itself, whereas with the normal rotation it does not.
Reviews
  1. private
    private
    Review by
    Posted on
Write Your Own Review
