Visu Demo Mobile
This example project shows new visualization elements and their usage on the basis of a fire engine. In addition, the example project demonstrates the efficient programming of web visualizations for mobile devices.
1.0.0.4
000040
The project simulates the handling and maintenance of a fire engine. The turntable ladder and the lamp post are extendable and can be positioned freely. The mixing ratio of water to fire extinguishing foam can be set and managed by a recipe. Any failure during service and maintenance is signaled by an alarm. The power of the generating set is represented via a trace element. In addition to some more functions the optical design is realized with special buttons and styles.
CODESYS Development System Version 3.5.14.0 or higher
CODESYS Control Version 3.5.14.0
All
Version Release Notes
Release Date
New visualization style
09.04.2020
- 07.08.2018
