Visu Demo Factory
The software package “Visu Demo Factory” includes a sample project with a visualization of a packaging system.
1.0.0.1
000076
The sample project shows what a visualization can look like and which visualization elements are available. The implemented packing system consists of several modules with states that can be simulated.
CODESYS Development System V3.5.8.0 or higher
CODESYS Control V3.5.8.0
All
Version Release Notes
Release Date
New visualization design
10.02.2020
- 07.08.2018
