Twitter Library
With the “Twitter Library”, messages (tweets) can be sent directly from the PLC to Twitter.
2.0.0.3
000047
With the TwitterLibrary, messages can be sent directly from the PLC to Twitter. Messages are sent via the “Rest API” from Twitter. Communication takes place via HTTPS and authentication by means of the OAuth protocol.
CODESYS Development System Version 3.5.14.0 or higher
CODESYS Control Version 3.5.14.0
Version Release Notes
Release Date
New visualization style
09.04.2020
- 07.08.2018
Reviews
Write Your Own Review
