Trend Example
The example project shows how to visualize and record values with the “Trend” element.
000058
The example project “TrendExample” contains three applications with different “Trend” configurations.
Following features are described in the example:
  • Conditional recording of values
  • Long term recording of values
  • Multiple recording of values
More information on the “Trend Element” and its configuration can be found in the CODESYS Help:
CODESYS Visualization > Visualization Elements > ‘Special Controls’ > ‘Trend’
