Softmotion Robotics HMI Example
The sample project ‘MotionHMI.project’ demonstrates some of the features available in SoftMotion Robotics. This project also includes a visualization and a Depictor object to visualize the movements. The project supports up to 6 axes.
Softmotion Robotics HMI Example with Companion Specification
The sample project ‘MotionHMI_Robot_Companion_Specification’ demonstrates an example implementation of the OPC UA Robot Companion Specification, with this the client application recives the specific data.
