Simulink PLC Coder(TM) Import
The CODESYS PlugIn “Simulink PLC Coder™ Import” makes it easy to import files and update components from Simulink PLC Coder™.
1.0.0.3
000062
The Tool “Simulink PLC Coder™ Import” allows the import of Simulink PLC Coder™ files and the update of imported components. All imported components can be updated automatically with or without confirmation. The update behavior can be set for each imported file.
See http://www.mathworks.com/products/sl-plc-coder/ for more information about Simulink PLC Coder™.
MATLAB and Simulink are registered trademarks of The MathWorks, Inc.
CODESYS Development System V3.5.10.0
Not relevant
Not relevant
Simulink PLC Coder
Version Release Notes
Release Date
Updated license agreement and company name
02.12.2020
Bugfix: Multiple files in import dialog
10.09.2018
- 07.08.2018
