Simple Webvisu Login
The example “Simple Webvisu Login” shows how to use the user management of the visualization and how to implement a simple login site.
1.0.0.1
000042
The example project SimpleWebvisuLogin.project shows how to use the following functions of the user management:
  • Login
  • Logout
  • Open user management
  • Change password
