Shared Memory
The shared memory can be used to exchange data within a target system when no direct communication is possible, e.g. the data exchange with an external visualization. How to create this shared memory and how to read and write to it is shown in this example.
1.0.0.1
000019
Two applications are used for demonstration. Both must run on one target device. The first one creates a shared memory and writes some values into it and the second one reads from it.
Whenever direct communication within a target system is not possible, shared memory can be used to exchange data.
