SFC Visu Generator
CODESYS Plug In to generate visualizations of SFC function blocks and SFC programs.
1.0.0.3
000067
The tool “SFC Visu Generator” generates visualizations of SFC function blocks and SFC programs. The current program step will be highlighted in the generated visualization at runtime.
CODESYS Development System V3.5.10.0 or higher
CODESYS Control V3.5.3.0
All
Highlighting of active macros is not supported
Version Release Notes
Release Date
Updated license agreement and company name
01.12.2020
New features:
  • Display time of step
  • Open macro via mouse click
12.02.2019
64 Bit Support
11.10.2018
- 07.08.2018
Reviews
Write Your Own Review
