Seven Segment Display
The example project contains an implementation of a seven segment display within CODESYS Visualization and the corresponding function blocks.
1.0.0.1
000061
The package contains the example project SevenSegmentDisplay.project including a visualization of four seven segment displays to show the value of an integer. The values of the digits can be incremented and decremented via buttons. The seven segment display is implemented modularly and can be easily adapted for individual requirements.
