Rockwell 1734 AENT Configuration
This example shows the configuration of a Rockwell 1734-AENT EtherNet/IP adapter with the I/O module 1734-IB4. The example can be used as base configuration for any product of the 1734-family. Detailed description is appended as pdf.
