Responsive Design Example
This example project shows how the design of visualizations can be adapted for various devices like monitors, tablets or smartphones.
000069
The package contains an example project concerning “Responsive Design”. The visualization in the project loads different visualizations depending on the screen size of the calling device. Thus it is possible to optimize the design for monitors, tablets and smartphones.
