PLC Chat
The PLC Chat includes a chat server which can handle up to 16 PLC clients and the client program. The chat UI is displayed on a CODESYS TargetVisu and can be accessed by the CODESYS Web Visualization.
000031
The PLC Chat includes a chat server which can handle up to 16 PLC clients and the client program. The chat UI is displayed on a CODESYS TargetVisu and can be accessed by the CODESYS WebVisu. This example demonstrates the usage of the library NetBaseServices.
Server:
  • Download the server application to a PLC and execute the program.
  • Enter the IP address for the server in the visualization configuration.
  • Choose a free port for the connection.
  • Give the chat a name (optional)
  • Now click the “Go Online” button.
  • The status bar changes from “not connected” to “waiting for clients”.
Client:
  • Download the client to another PLC and run the application (up to 16 PLCs can participate)
  • Change to the configuration tab
  • Choose your nick name.
  • Enter the IP address and port of the server
  • Click the “Go Online” button.
  • The status bar now displays “connection established”.
