IO Mapping Tool
With the IEC library “IO Mapping Tool”, the inputs and outputs of a program can be remapped via a visualization in runtime mode.
1.0.0.1
000092
The inputs and outputs are mapped via function blocks and the corresponding visualizations. In doing so, the function blocks are simply activated between the desired inputs our outputs.
The library contains the following function blocks.
  • Function blocks with eight inputs and outputs:
    • Basic function block
      • Function block for BOOL inputs and outputs
      • Function block for BYTE inputs and outputs
      • Function block for WORD inputs and outputs
  • Function blocks with a variable number of inputs and outputs:
In the function blocks IOMappingBool, IOMappingByte, and IOMappingWord, eight variables each of the corresponding type are used for the inputs and outputs.
Function blocks with variable inputs and outputs
In the function blocks VarIOMappingBool, VarIOMappingByte, and VarIOMappingWord, the inputs and outputs are mapped via arrays of length g_iMaxIOs. The parameter g_iMaxIOs can be edited via the parameter list Param and it can be maximum 256.
Basic function blocks
In the function blocks IOMappingBaseFB and VarIOMappingBaseFB, an array of integer values is created for each. The indices of the array represent the inputs and the values at the corresponding positions represent the outputs for these inputs. Only one input can ever point to an output. When changing the mapping of inputs and outputs, it is checked if the output has already been mapped to an input. If this is the case, then the value of the earlier input is set to -1. The array that saves the mapping of inputs to outputs is stored with the PersistenceManager.
