HTTP Client Example
With the function block “HTTP Client”, http requests, as well as the resulting responses, can be exchanged between a CODESYS controller and a web server.
1.0.1.1
000075
The CODESYS software package includes a library with a function block for communicating with a web server via HTTP.
  • When using http-GET, data is requested from a web server.
  • When using http-POST or http-PUT, data is submitted from the controller to a web server.
  • When using http-DELETE, data is deleted on a web server.
  • When using http-HEAD, http-Header is requested from a web server.
The HTTP header of a request can be extended without any restrictions. The library is included as source code in the CODESYS package.
