Device Reader
This tool reads the available features of a device. A visualization shows if a feature is available or not.
1.0.0.6
000007
The Device Reader is designed as standalone application and should not be integrated into another application, because demo mode for all features will be disabled by the device reader.
CODESYS Control V3.5.14.0
All
License check of the OPC UA client added
11.08.2021
New Features:
  • Added new licenses checks
  • Improved visualization
07.12.2018
- 07.08.2018
