Date and Time
The example shows how to use the date and time functions of the SysTime and Util libraries.
1.0.0.1
000006
The project contains examples on the following topics:
  • Reading timer tick values since system startup
  • Read UTC time
  • Convert UTC time to local time
  • Local time and time zone operations
