Communication with HALCON
This example shows how a communication between HALCON and CODESYS can be realized via TCP / UDP protocol. In the CODESYS programs the “CAA Net Base Services” library is used.
000029
This example shows how to communicate with a HALCON program via TCP and UDP.
There are three parts of the example that demonstrate the following:
Part 1: The CODESYS TCP-Server communicating with HALCON TCP-Client.
Part 2: The CODESYS TCP-Client communicating with HALCON TCP/UDP Server.
Part 3: The CODESYS UDP-Peer communicating with HALCON TCP/UDP Server.
CODESYS Development System Version 3.5.1.0 or higher
CODESYS Control Version 3.5.1.0
All
Halcon 11.0.1 (Download http://www.halcon.de/halcon/download/)
TCP_Client.hdev
TCP_UDP_Server.hdev
Version Release Notes
Release Date
- 07.08.2018
