CODESYS Web View
Quick and easy management of web visualizations in the local wireless LAN network.
000091
The Android app ‘CODESYS Web View’ searches the local wireless LAN network for web visualizations. The URLs of web visualizations found are saved in a list. To view a certain web visualization, the corresponding URL can be clicked.
Download via Google Play Store: https://play.google.com/store/apps/details?id=com.codesys.webview
Programming system
Target system
CODESYS Control V2, V3
Supported platforms / Devices
Additional requirements
The search function browses all IP addresses in the local wireless LAN network to finds web visualizations. In order to find a web visualization, the following conditions have to be met:
  • Web server runs on port 8080, 9090 or 443 (https)
  • Name of visualization: webvisu.htm
  • Network template 255.255.255.0
Required accessory
No version information available.
