CODESYS Virtual Control SL
Scalable, hardware-independent, easy to maintain, secure - with CODESYS Virtual Control SL, you can use the next generation of soft PLC on almost any x86- or ARM-based Linux device, with any number of instances and scalable performance.
4.23.0.0
000138
Take the next step towards complete hardware independence! With CODESYS Virtual Control SL, you can use the next generation of the IEC-61131-3 compatible CODESYS Soft PLC. The containerized runtime can be operated on almost any x86- or ARM-based hardware. From compact standard controllers to IPCs and powerful IT servers.
The merging of the IT and OT worlds opens up new possibilities. Nothing stands in the way of centralizing the control landscape. Benefit from immense cost savings in hardware procurement, wiring, operation and maintenance. Simple scaling thanks to dynamic creation of control instances and the ability to expand hardware independently of software makes you more flexible than ever before. Splitting tasks across several independent, containerized control instances with powerful intercommunication increases security enormously. The possible use of IT methods, systems and orchestration also simplifies the maintenance of your virtual controllers, from runtime updates to changing the application.
You can easily install and instantiate the CODESYS Virtual Control on your target system via the CODESYS Development System. Depending on the performance of the used hardware, dozens of containerized runtime systems can potentially be operated in parallel.
Programming system
CODESYS Development System V3.5.20.10 or higher
Runtime system
CODESYS Virtual Control SL V4.12.0.0 or higher
Supported platforms
  • OS: Debian Linux, RedHat Enterprise Linux, Yocto Linux
  • CPU: x86-64, ARM, ARM64
Additional requirements
  • Support of a container engine required (Docker/Podman)
  • Kernelversion >= 6.1 (Debian 12 - OSADL-Dockerimage)
  • Python3, SSH Server preinstalled
  • Network license server available (CODESYS LicenseServer)
  • IProute2 preinstalled
  • Optimization of realtime capabilities of the system:
  • Hardware, BIOS, RT-Preempt-Kernel, no graphical UI
Limitations
No support for WSL (Windows subsystem for Linux) based systems
Application-based network license: The runtime system is licensed via application-based licenses that are provided by a license server. The number of licenses determines how many controllers can be supplied at the same time.
The license server can be operated in the local network or locally on the same device on which the controllers to be licensed are running.
Note: Without a license, each controller runs in demo mode for two hours.
Required accessories
CODESYS LicenseServer for Linux SL
  • Docker Compose support: a Compose file can now be exported directly from the CODESYS Control SL Deploy Tool; the network NIC mapper is part of the package
  • Updated CodeMeter Runtime to version 9.10
22.10.2026
17.08.2026
  • XDP support of Ethercat and Profinet on x86 devices
18.06.2026
01.04.2026
12.02.2026
16.10.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 P2
26.08.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 P1 03.06.2025
Update on CODESYS Runtime Toolkit V3.5 SP21 07.04.2025
03.12.2024
Support of network licensing
29.08.2024
03.07.2024
