This product is currently in the Service Phase, and its discontinuation has already been scheduled. We therefore recommend that you only use it for existing projects. Other solutions are available for new developments. We have compiled these for you on our website. Here you will also find the discontinuation dates for products in the Service Phase: Discontinuations
CODESYS V2.3 Converter
The CODESYS V2.3 Converter enables you to open and import projects edited with CODESYS V2.3 with CODESYS V3.5.
