CODESYS UML Demo
CODESYS UML allows to create the application in two languages, the UML class diagram and the UML state diagram.
CODESYS UML is part of the tool bundle CODESYS Professional Developer Edition.
4.4.0.0
2101000001
The UML (Unified Modeling Language) is a graphical language for specification, design and documentation of object oriented software. UML provides a generally intelligible discussion basis between programming and other company divisions within system development.
UML consists of 14 different diagram types in two main categories: structure diagrams and behavior diagrams. Structure diagrams schematically illustrate the architecture of software and are basically meant for modeling and analysis (e.g. project design, specification of system requirements or documentation). Behavior diagrams are executable models with distinct syntax and semantics, which directly generate application code („model driven architecture“).
CODESYS UML extends the CODESYS Development System with two new diagrams of the Unified Modeling Language: the class diagram and the state diagram, for the 32 Bit and 64 Bit version of the CODESYS Development System in one package.
CODESYS Development System V3.5.19.30 or higher
Subscription of the CODESYS Professional Developer Edition.
64 Bit support with version 4.0.3.0 and higher
see CODESYS Professional Developer Edition
Required accessories
Detailed compatibility information
Version
Programming System Version
4.4.0.0
3.5.19.30 - newest
4.3.0.0
3.5.19.30 - newest
4.2.2.0
3.5.16.0 - newest
4.2.1.1
3.5.16.0 - newest
4.2.1.0
3.5.16.0 - newest
4.2.0.1
3.5.12.0 - newest
4.1.1.0
3.5.12.0 - newest
4.1.0.0
3.5.3.0 - newest
4.0.5.0
3.5.3.0 - newest
4.0.4.0
3.5.3.0 - newest
4.0.3.0
3.5.3.0 - newest
4.0.2.1
3.5.3.0 - newest
4.0.2.0
3.5.3.0 - newest
4.0.1.1
3.5.3.0 - newest
4.0.1.0
3.5.3.0 - newest
4.0.0.3
3.5.3.0 - newest
4.0.0.2
3.5.3.0 - newest
4.0.0.1
3.5.3.0 - newest
4.0.0.0
3.5.3.0 - newest
Version Release notes Release date
Release and Teaser Notes.
23.07.2024
- 20.04.2020
New Feature:
  • Viewer and deploy tool (no widget type="Codesys\AllVersionWidget\Block\Widget\AllVersion" required)
  • Online Change des State Chart
13.12.2018
Support of Softcontainer licensing (no Dongle needed)Changes to transitions can be performed with an online change.The semantics of an exception transition match the UML 2.0 specification
07.05.2018
Usability improvements and bug fixes.
30.01.2018
27.07.2017
02.11.2016
28.09.2016
See Features and Changes for more information.
17.05.2016
18.03.2016
30.07.2015
30.03.2015
- Added UML-specific compiler version handling.- Localization of user interface DE and EN.
27.08.2014
  31.01.2014
