CODESYS Test Manager
The CODESYS Test Manager lets you program and run automated tests for applications and libraries developed with CODESYS (32-bit and 64-bit), both interactively and in CI/CD pipelines. It is part of the CODESYS Professional Developer Edition tool bundle.
