This product is currently in the Service Phase, and its discontinuation has already been scheduled. We therefore recommend that you only use it for existing projects. Other solutions are available for new developments. We have compiled these for you on our website. Here you will also find the discontinuation dates for products in the Service Phase: Discontinuations
CODESYS SVN
CODESYS SVN enables an integrated connection to the software versioning system Apache™ Subversion® for all application objects.
CODESYS SVN is part of the tool bundle CODESYS Professional Developer Edition.
4.6.3.0
2101000000
Apache™ Subversion® (SVN) is a tool for versioning and revision control of current and historical versions of files such as source code, web pages, and documentation. Apache™ Subversion® is a registered trademark of the Apache Software Foundation. See the package information in the package manager for more information.
Revision control, also known as version control or source control, is the management of changes to documents, programs, and other information stored as computer files. It is most commonly used in software development, where a team of people may change the same files. The main tasks of a version control system are:
  • Log of changes: It can be reproduced at any time what changes have been made, when and by who these changes have been made.
  • Restore of old revisions of single files. Changes of files by mistake can be undone at any time.
  • Archiving of specific revision of a project. It is always possible to go back to older versions.
  • Coordination of shared access of developers.
  • Simultaneous development of multiple branches of a project.
The Subversion functions are directly available in CODESYS both in the 32-bit and in the 64-bit variant. The application is seamlessly integrated in the CODESYS development environment.
CODESYS SVN can be installed and started in the CODESYS Development System without a license. To connect to an SVN repository, a license key is required in the demo as well as in the full version.
CODESYS Development System V3.5.19.30 or higher
Subscription of the CODESYS Professional Developer Edition.
  • A running Subversion project archive (repository) on a server or locally in a file
  • Installation of the Redistributable Package für Microsoft Visual Studio 2015
For information on how to work with Subversion or how to install the required software please contact your local IT specialist.
none
see CODESYS Professional Developer Edition
Required accessories
Detailed compatibility information
Version
Programming System Version
4.6.3.0
3.5.19.30 - newest
4.6.2.0
3.5.19.30 - newest
4.6.1.0
3.5.19.30 - newest
4.6.0.0
3.5.19.30 - newest
4.5.0.0
3.5.19.30 - newest
4.4.0.0
3.5.17.0 - newest
4.3.0.0
3.5.16.0 - newest
4.2.7.0
3.5.16.0 - newest
4.2.6.0
3.5.16.0 - newest
4.2.5.1
3.5.9.50 - 3.5.15.x
4.2.5.0
3.5.9.50 - 3.5.15.x
4.2.4.0
3.5.9.50 - 3.5.15.x
4.2.2.0
3.5.9.50 - 3.5.15.x
4.2.1.0
3.5.9.50 - 3.5.15.x
4.2.0.0
3.5.9.50 - 3.5.15.x
4.1.2.1
3.5.9.50 - 3.5.15.x
4.1.1.0
3.5.9.50 - 3.5.15.x
4.1.0.2
3.5.9.50 - 3.5.15.x
Release and Teaser Notes
09.10.2024
Release and Teaser Notes.
16.07.2024
Release Note
  • [SVN-1121] ScriptDriver: Add connect_project to UnversionProject.
Major Bug-Fixes
  • [SVN-571] Revert, Commit: Revert an added POU in the Commit dialog leads to assertion
  • [SVN-701] Automatic locking: Update option lacks selection verification hooks
  • [SVN-750] Repository Browser: opening the context menu for 2 objects leads to an exception
  • [SVN-1022] Update SharpSvn to integrate security fixes in its dependencies
  • [SVN-1026] Error on resolving a tree conflict using theirs
  • [SVN-1051] Child nodes are modified after steal lock recursively
  • [SVN-1058] SVN: Commit can lead to Update project in Online mode
  • [SVN-1059] SVN: Copy and Paste of a long-char-folder-structure containing FBs leads to wrong Commit
  • [SVN-1060] SVN Checkout sporadically causes IEC compile errors
  • [SVN-1079] SVN Working Copy Explorer: Foreign locks not shown
  • [SVN-1082] Revert: Impossible to revert changes in project settings
  • [SVN-1107] SVN: Crash on Compare for non-versioned node
  • [SVN-1127] SVN operations via scripting may fail because of missing license
  • [SVN-1135] After renaming controller and commit some objects remain checked in commit window
  • [SVN-1151] Compare to base revision of added object fails with exception
  • [SVN-1175] RepositoryBrowser: Objects inside a project can be renamed
Minor Bug-Fixes
  • [SVN-757] SVN Working Copy Explorer: Unhandled Exception when updating selected nodes without a license
  • [SVN-919] SVN error when reconnecting to existing project with Persist SVN_Version_Info option
  • [SVN-921] Persist SVN_Version_Info option is not stored on SVN Import and can sometimes lead to an exception
  • [SVN-960] SVN Error in a loop after compare with revision window is canceled
  • [SVN-991] CODESYS crashes after selecting an entry in pending changes view
  • [SVN-1015] Drag & Drop on itself sporadically deletes and re-adds object
  • [SVN-1172] Remove PuTTY from SharpSVN bundle
Compatibility Information
General
This version is compatible with CODESYS V3.5 SP19 Patch 3 and newer.
    While being online on a device no svn update is possible
    The following changes were made to the working copy explorer:
    • the command “Locks > Revalidate Locks” is always enabled, if svn is not in offline mode
    • the columns “Lock” and “Lock comment” now show the lock info of remote locks, if available and no local lock exists
    The revert dialog for the command ‘Revert project’ now offers the option to revert the whole project. If this option is chosen, the possibility to select single objects is disabled. The revert dialog for the command ‘Revert’ on single objects does not offer this option.
Known Limitations
Information from JIRA
List of features and changes:
project = “CODESYS SVN” AND fixVersion = 4.6.0.0
project = “CODESYS SVN” AND fixVersion = 4.6.0.0 AND (text ~ COMPATIBILITY_INFORMATION OR text ~ KNOWN_LIMITATIONS)
02.05.2024
Required CODESYS version
Improvements
  • SVN-1065: Created the possibility for device manufacturers which use their own licensing mechanisms for the engineering environment to integrate the CODESYS Professional Developer Edition into their systems. The following packages are required for proper functionality. If not using CODESYS Installer the user must install them manually.
    • CODESYS License Provider (ID “CODESYS.LicenseProvider”) or OEM equivalent
    • CODESYS License Provider Enabler (ID “CODESYS.LicenseProviderEnabler”)
    • CODESYS Licensing Support (ID “CODESYS.Licensing.Support”)
Bug fixes
05.10.2023
CODESYS V3.5 SP17
Improvements
  • SVN-970: Disconnect: Release locks before disconnecting
  • SVN-986: Introduce storage profile compatibility checks to mitigate the risk of data loss
Bug fixes
  • SVN-612: Log: “Show changes” fails, if comparison base is masked by filter
  • SVN-708: Log: A date filter before first revision cannot be deleted
  • SVN-1042: “Revert to revision” on included externals does not recognize a move out of subtree
  • SVN-914: Security: Prevent abuse of storage profile file (see Advisory 2021-13 on the CODESYS website)
  • SVN-947: Security: Regular update of SharpSvn library to include OpenSSL fixes
  • SVN-901: Merge: Rename object state “Special” to “Incoming”
  • SVN-951: Prevent corruption of project by regular copy-paste-rename workflow
  • SVN-971: Provide solution for tree conflict caused by concurrent deletion
28.07.2022
CODESYS V3.5 SP16
Improvements
  • SVN-902: Provide documentation for SVN script driver
Bug fixes
  • SVN-910: SVN_VERSION_INFO doesn’t disappear anymore with option “persist after disconnecting”
  • SVN-897: SharpSvn: Update to most recent version for security fixes
21.10.2021
CODESYS V3.5 SP16
Improvements
  • SVN-877: Improve performance of importing project into SVN
  • SVN-875: Improve UI performance of SVN operations
  • SVN-158: Improve performance of opening and saving a project with SVN connection
Bug fixes
  • SVN-863: Fix failing generation of SVN_VERSION_INFO object in some special cases
  • SVN-818: Fix project inconsistency because of SelectionVerificationHooks not working for subtree commits
  • SVN-864: Fix missing SVN_VERSION_INFO object leading to corrupted working copy
  • SVN-833: Fix failing object renaming after revert / undo
  • SVN-765: Fix exception after drag and drop of task configuration object
  • SVN-322: Fix exception in Repository Browser for non-existing directory
  • SVN-756: Fix incomplete log display after having moved project in repository
  • SVN-884: Fix sporadic crash when exiting IDE without having opened the log view
  • SVN-848: Update 3rd party libraris to integrate security bug fixes
  • SVN-829: Mitigate error behaviour for conflicted object properties
  • SVN-769: Fix credentials still being cached after having run “Clear authentication data”
15.01.2021
Improvements
  • SVN-780: Improve performance for comparison of a single object between BASE and WORKING revision
Bug fixes
  • SVN-842: Prevent SVN update (and other SVN operations) while application is logged in
  • SVN-798: SVN log sporadically not displayed, instead error “Value cannot be NULL”
  • SVN-794: Tree conflict leads to exception during checkout and cannot be resolved afterwards
  • SVN-834: SharpSvn: Disable SharpPLink (Putty/PLink) because of security bugs
  • SVN-811: SharpSVN: Update to OpenSSL 1.1.1d
  • SVN-812: CODESYS crashes if project import fails due to repository pre-commit hook
  • SVN-813: Deleting an object in the Working Copy Explorer does not update the object’s status in the project session
  • SVN-817: Assertion when re-adding a child device under a copy it’s a parent device
  • SVN-816: “Select All” in Pending Changes View sometimes leads to exception
  • SVN-772: Deadlock of Repository Browser while refreshing
  • Upgrade to OpenSSL 1.1.1d
  • Disabling the ability to use SharpPlink
18.02.2020
Release Note
CODESYS SVN 4.2.5.0 is a bug-fix release.
Major bug-fixes
  • [SVN-768] Upgrade to OpenSSL 1.1.1 (1.0.2 is reaching end of support) and Apache subversion 1.12
  • [SVN-799] Assertion (missing SvnWorkingCopySummary) when cancelling the project import to SVN
  • [SVN-801] Disconnecting project from svn via python leads to an error (SvnWorkingCopyVersionSummary)
  • [SVN-802] SVN Update doesn’t handle tree conflict, aborts with assertion instead
  • [SVN-803] SVN, Scripting: Reentrant lock when setting release flag of library
2 minor bugs have been fixed.
General
This version is compatible with CODESYS V3.5 SP9 Patch 5 and newer.
Known Limitations
  • [SVN-802] There are situations implied by a tree conflict, that relate to the object naming scopes of a CODESYS project: It is impossible to apply an incoming addition of an object, whith a name that already exists in the same namespace. This can happen when using folders in a CODESYS project, because they are namespace-agnostic, whereas the file system folders of the Working Copy create each a namespace. In this situation the SVN update operation will yield an exception like “An object with the name ‘TheObjectName’ already exists within the corresponding namespace.”
11.09.2019
16.05.2019
01.10.2018
 SVN_VERSION_INFO object default settings for persistence have been changed.
22.08.2018
Security updates:
  • For more details see Advisory 2018-03, which is available on the CODESYS website:
https://customers.codesys.com/fileadmin/data/customers/security/2018/Advisory2018-03_SVN-632.pdf”
General information:
  • Support multiple diff-views at once for compare
  • The SVN_VERSION_INFO object now is available even if there’s no connection to the SVN repository.
  • SVN has now a view “Pending Changes” which shows the current changes to the existing project version.
  • “Revert to revision” now is able to revert the whole subtree under a single selected object.
  • The SVN_VERSION_INFO provides instantly updated information.
  • The SVN Log dialog just loads the first 100 log entries.
  • When merging, for conflicting names the affected nodes are marked with a tree conflict marker, keeping the local state of the object.
  • New button “Mark as Resolved” within the resolve conflict dialog.
  • The background check for remote repository changes now is configured to recognize release of locks as well.”
15.03.2018
CODESYS SVN 4.1.2.1 is a security update which solves the issue noted in Advisory 2017-08.For more details see:https://customers.codesys.com/fileadmin/data/customers/security/2017/Advisory2017-08_SVN-585.pdf 29.09.2017
- 26.04.2017
- 24.10.2016
This is a bugfix release
25.02.2026
