CODESYS Sensor App for Android
With the product “CODESYS Sensor App for Android”, the sensor data of from an Android smartphone can be sent to a CODESYS controller.
1.7.0.1
000073
Numerous sensors are integrated in smartphones, such as Hall Effect sensors, acceleration sensors, and GPS sensors. With the “CODESYS Sensor App for Android”, the data of the most popular sensors can transmitted from an Android based device to a CODESYS controller over an IT network connection. In addition, the voice recognition of Android can be used for transmitting recognized words as strings to the controller. When an Internet connection is available, simple speech recognition can be established with the Android device (e.g. smartphone).
The software package also includes a sample project for the CODESYS Development System for viewing the transmitted data in a visualization.
CODESYS Control V3.5.14.0
All
  • Network connection between the Android device and the CODESYS controller
  • Internet connection (for voice control)
  • Android device (e.g. smartphone)
  • CODESYS capable controller
Version Release Notes
Release Date
Bugfix for CODESYS 3.5.17.0
17.08.2021
Minimum CODESYS version 3.5.14.0
Improvement:
  • Voice recognition now works with multi languages and WSTRINGs
23.07.2019
- 07.08.2018
