Safety without compromise: With CODESYS Safe Control SL, you get a certified SIL3 controller without any special hardware requirements. Install it natively on your commercial-off-the-shelf hardware and experience maximum safety - only with CODESYS.
Its safety functionality is based on the certified component CODESYS Safe Control Core - safety manual and certificate of the core apply to this product.
Immerse yourself in the future of industrial control technology with CODESYS Safe Control SL. This software solution redefines safety and sets new standards in performance, flexibility and efficiency. Developed without hardware requirements according to IEC 61508, it offers you unrivalled freedom in your choice of industrial hardware.
The benefits are unrivalled: By eliminating the need for IEC 61508 hardware certification, you significantly reduce your time-to-market. With CODESYS Safe Control SL, you can use the software directly without having to carry out time-consuming hardware tests. The use of the latest CPU generations guarantees impressive performance that takes your production processes to a new level.
Safety first: With a hardware fault tolerance (HFT) of 1 and a probability of failure (PFH) of maximal 1 * 10 -10, CODESYS Safe Control SL offers unrivalled safety. The safe control system is installed natively on the Linux operating system as a Debian or RPM package and runs alongside the standard controller on the same device. Discover today how CODESYS Safe Control SL can optimise your production processes and lead your company safely into the future.
CODESYS Safe Control SL is the natively installed variant of the safe control system. If you want to operate the safe control system as a Linux container, the CODESYS Virtual Safe Control SL product is available for this purpose.
The license cost is based on the number of safe connections defined in the IEC application. The number of safe connections is therefore equal to the number of assigned safe addresses (e.g. number of assigned F-addresses for Profisafe). Only safe connections are counted, exchange variables for data exchange with standard PLC are not counted.
Programming system
Runtime system
CODESYS Control for Linux SL V4.23.0.0 or higher
CODESYS Control for Linux ARM SL V4.23.0.0 or higher (64-bit variant)
Supported platforms
Debian Linux (x86-64, ARM64)
RedHat Enterprise Linux (x86-64)
Additional requirements
Control SL to run PROFINET and/or EtherCAT communication
Second independent time source
Optimisation of Linux version for real-time (RT_preempt patch)
Limitations
When using the CODESYS Safe Control SL, the information in the associated Release Information Document must be observed!
When using the CODESYS Safe Control SL, the workarounds in the CODESYS Safe Control Core Errata List must be taken into account.
Required accessories
CODESYS Safe Control SL is released for the first time with this version. It contains the native safety runtimes, which were previously delivered as part of the CODESYS Virtual Safe Control SL package.
Based on CODESYS Safe Control Core 4.3.0.0, supporting the ARM64 and x64 architectures
