The CODESYS PROFINET Device SL is not compatible with application-based licenses.
The CODESYS PROFINET Device enables a CODESYS PLC to act as a PROFINET Device that is programmable with the CODESYS Development System.
2303000021
€100.00
PROFINET (Process Field Network) is an open standard for realtime industrial Ethernet systems in automation technology. It is promoted by the user organization PI (PROFIBUS & PROFINET International as an umbrella group of the PROFIBUS user organization PNO) and is regarded as the successor of PROFIBUS. PROFINET uses UDP/IP and IEEE 802.3 (Standard Ethernet) for acyclic services and/or I/O communication
The fully integrated CODESYS PROFINET Device Solution provides a uniform configurator for different variants of underlying PROFINET Device communication stacks:
  • CODESYS PROFINET Device (IEC)
    Protocol stack in the form of a CODESYS library (in IEC 61131-3 code), operates on standard network interface cards.
    The Ethernet adapter is not used exclusively, it’s still available for all other applications using TCP/IP on this adapter (e.g. CODESYS Visualization, Web Browser).
CODESYS PROFINET Device Configurator
  • Configurator for settings of PROFINET Device
  • Sample GSDML file included in scope of delivery
  • Configuration of module’s in- and output-mapping
  • Status page with detailed view of currently pending diagnostics
Profinet-Stack (IEC)
CODESYS PROFINET Device Stack in principle can run on any standard Ethernet adapter hardware (see requirements and restrictions). This Ethernet adapter is still be used for other services like CODESYS Communication (with IDE), Web-Server, or other CODESYS Fieldbuses (except EtherCAT). The CODESYS Runtime and the operating system (e.g. firewall) have to be configured correctly. For details, see CODESYS Online Help / Fieldbus Support (https://help.codesys.com/)
Feature
PROFINET Specification
V2.46
Conformance Class
B
Max. IO-Data
1440 input and 1440 byte output
Max. acyclic data
16 KB
Platforms / OS (see restrictions)
Windows, Linux, VxWorks
CPU
32/64 Bit
Little-/Big-Endian
Provider-/Consumer-Status
yes
Shared Device
no
Device Access AR
no
Dual Port
see below
MRP
Client, see Dual Port
CODESYS PROFINET Device (IEC) and Dual-Port Interface:
With standard Ethernet Adapter hardware only single port devices are possible, i.e. each PROFINET Device can handle just one port. (The system itself may have more than one Ethernet adapter, maybe running a PROFINET Controller on it).
A Dual-Port Device (e.g. for MRP support or a ‘daisy-chain’) may be implemented with special dual-port Ethernet chipsets, but this requires some runtime adaptions by the OEM.
Programming Interface (API for IEC application)
The PROFINET Device provides an API for Profinet related functions and utilities that can be used by the application at runtime.
Function
Description
Generic access on device- and module-configuration
Function Block ProfinetCommon.DeviceIterator and SubmoduleIterator
Generic API for iterating Slave- or Module Configuration and Status
Add/Remove Diagnosis Entries
Function Block ProfinetCommon.UpdateDiagnosisEntry
Update the device’s local Diagnosis Database, send diagnosis-alarm
Send Alarms
Function Block CommFB.SALARM
Acyclic Services
Function Block CommFB.PRVREC / RCVREC
e.g. Receive Parameters from PROFINET Controller
Connection Establishment
Function Block ProfinetCommon.DeviceAR
A Profinet Device application uses this function block for controlling all phases of the connection establishment.
Reconfigure
Function Block DED.Reconfigure
Enable/Disable modules or the complete PROFINET stack
Programmatic Configuration
Alternatively to the usual configuration with a declaration via the device tree, the PROFINET Device can also be configured purely programmatic.
The library ProfinetDeviceConfig provides a programming interface which does not require instances of device objects.
CODESYS Control V3.5.17.0 or higher CODESYS Control V3.5.17.30 or higher required for certification
CODESYS runtime system with these components
* SysEthernet
* SysSocket
Technical requirements
* Ethernet Adapter (for Control RTE with Intel or Realtek chip)
Legal requirements
A certification by a PI Test Lab is mandatory for every PROFINET Controller or Device that is sold to end-users.
Details on certification can be found here:
www.profibus.com/products/product-certification/
Certification is currently possible for
* Control RTE > V3.5.18.30
* Linux based runtimes > V3.5.17.30
