Company Holidays: December 22, 2025 – January 5, 2026
CODESYS Package Designer
The CODESYS Package Designer provides an intuitive user interface and wizards for creating CODESYS packages, which can be used to extend CODESYS.
4.2.0.0
000033
The CODESYS Package Designer is an integrated tool that supports the creation of CODESYS Packages. Packages are used to add additional functions and configuration settings to existing CODESYS installations. For this purpose, the CODESYS Package Designer offers an interface to create and edit packages to add wizard-guided content.
The plug-in can be started in the menu command Tools -> Package Designer.
CODESYS Development System Version 3.5.17.0 or higher
- 19.06.2024
- 09.08.2023
- 07.11.2022
- 05.05.2020
- 29.07.2019
17.12.2018
- 10.07.2018
