This product is currently in the Service Phase, and its discontinuation has already been scheduled. We therefore recommend that you only use it for existing projects. Other solutions are available for new developments. We have compiled these for you on our website. Here you will also find the discontinuation dates for products in the Service Phase: Discontinuations
CODESYS OPC DA Server SL
The CODESYS OPC DA Server SL enables direct OPC DA communication with all CODESYS programmable controllers.
3.5.22.40
2302000028
€175.00
The OPC DA Server is able to communicate with both, V3 as well as V2.3 PLCs, at the same time. Furthermore a missing PLC can be simulated. Then a symbol file with all symbols instead of the PLC provides the OPC DA server the symbol pool (XML file or SDB file).
A detailed description of all functionalities and commissioning can be found in the CODESYS OPC DA user guide (part of the setup).
CODESYS Development System V3 or V2.3
CODESYS Control V3 oder V2.3
Windows 8/10
OPCConfig (part of the setup)
Note: A 30-day demo license is available for this product.
Includes the following Security fixes: 2026-11
30.09.2026
- 23.07.2026
- 20.05.2026
- 02.04.2026
- 24.03.2026
- 22.04.2026
Includes the following Security fixes: 2025-09, 2025-10, 2025-11
01.12.2025
- 25.09.2025
- 04.08.2025
- 26.05.2025
- 18.03.2025
- 21.05.2026
- 22.04.2025
- 23.01.2025
- 20.11.2024
- 23.09.2024
- 31.07.2024
- 04.06.2024
- 19.03.2024
- 02.05.2024
- 06.02.2024
- 04.12.2023
- 23.10.2023
05.10.2023
- 03.08.2023
- 01.06.2023
- 08.03.2023
- 31.10.2023
- 04.05.2023
- 13.12.2022
- 06.10.2022
Includes the following Security fixes: 2022-10
03.06.2022
Includes the following Security fixes: 2022-04
06.04.2022
- 28.10.2022
- 10.06.2022
- 25.01.2022
- 02.11.2021
- 23.07.2021
Includes the following Security fixes: 2020-06, 2021-01
28.04.2021
- 18.08.2021
- 26.05.2021
19.09.2019
- 29.07.2019
23.08.2019
17.12.2018
18.01.2019
- 23.08.2018
- 10.07.2018
13.11.2018
- 20.12.2017
- 16.02.2018
- 18.02.2026
