The CODESYS Modbus TCP Client SL is not compatible with application-based licenses.
CODESYS Modbus TCP Client is a product for extending the functionality of CODESYS compatible devices. Using a standard Ethernet adapter, Modbus clients are created from these devices. In this way, configured devices exchange data with Modbus TCP Servers.
2303000001
€50.00
The CODESYS Modbus TCP Client configurator, which is integrated in the CODESYS Development System, expects a license on the device. This license is either already stored in the controller by the device manufacturer or added afterwards by the end user. The product is also available for Modbus Client (RTU).
The license is saved to a CODESYS compatible device — on CODESYS Key (hardware device) or Soft Key (software license container). If a license for the CODESYS Modbus TCP Client is available on the device to be programmed, then the device can communicate with connected adapters and read and write their inputs and outputs, respectively. For this purpose, the communication parameters are predefined in the configurator, for example the settings of the Ethernet adapter (baud rate, port number).
Modbus commands are defined in the configurator and are oriented to a specific Modbus server. The commands are processed by the device at specific intervals, or triggered programmatically. For predefined commands, I/O channels are generated automatically with variables that can be mapped (I/O mapping).
Processing requires a protocol stack and CODESYS I/O driver that implements Modbus communication on the configured Ethernet port. This I/O driver is supplied with the license as CODESYS libraries. The I/O driver also supports CODESYS Redundancy and CODESYS Connectivity Redundancy.
CODESYS Control V3.5.17.0 or higher
  • CODESYS Control runtime system on the device with SysSocket component
  • Available Ethernet adapter on the device
  • Optional: CODESYS Connectivity Redundancy SL license (only required if the corresponding feature is used)
Max. 64 Modbus TCP Servers
